tractormech
Anybody have this bucket leakdown issue? It has a switch at the upper left that you flip to enable the auto level feature.It would work right and then start leaking down, Then start working right again. Now it leaks down all the time I capped the tilt cylinders off and the leakdown stopped so I know the cylinder seals are holding.Anyone ever dealt with this issue before? I hope there's a cartridge valve that can be replaced without changing the whole block.Any help or advice from anyone would be appreciated. Thanks!
