24 ft goose neck rewire
Discussion in 'Trailers' started by banditman, Feb 25, 2020.
  1. banditman
    banditman Member
    Apr 25, 2013
    12
    randolph utah
    I got a 24 foot goose neck flatbed that needs to be rewired. What i would like to know is what is the best method for doing this? Should i buy a long piece of 7 strand wire and run all the way down and wire the lights brakes ect off that or should i run individual wires to do each light and brake? What are the best wire connectors for being in a salty wet environment? The trailer has dual tail lights meaning that there are two on the right and two on the left and they have never worked correctly should both lights blink when your signaling or just one? Should i add a junction box up at the front to connect everything to?
  2. Spud_Monkey
    Spud_Monkey Senior Member
    Sep 15, 2018
    1,640
    Retired Combat Vet Mechanic/Welder
    46.044135 -106.160555
    Junction box up front then run 7 strand wire to first axle and then split it off from there to brakes and remainder wires to the back going down one side. I Suggest Ancor heat shrink connectors, never use wire nuts, those are for solid wire only. Depends on the bulb type if the two lights on back should blink together or just one or are they LED's?
    Fat Dan, RZucker and hvy 1ton like this.
  3. banditman
    banditman Member
    Apr 25, 2013
    12
    randolph utah
    they are LEDs
  4. banditman
    banditman Member
    Apr 25, 2013
    12
    randolph utah
    They are LEDs
  5. Tags
    Tags Senior Member
    Feb 19, 2012
    1,071
    Connecticut
    RZucker likes this.
  6. Spud_Monkey
    Sep 15, 2018
    1,640
  7. Spud_Monkey
    Sep 15, 2018
    1,640
    Not wired right sounds like.
  8. Ronsii
    Ronsii Senior Member
    Jun 26, 2011
    3,544
    s/e Heavy equipment operator
    Western Washington
    Run the 7wire to the junction box then split the brake circuit off with 2 12ga. Double insulated brake wires and run them to each brake. Then you can run a 4wire to the tail lights and split off from there for the markers or run a separate marker wire right from the box if you wan to... Also most manufacturers run a ground wire with each circuit but to simplify things you could use the frame...and of course wire in the breakaway and battery at the box
    And like others have said use good heat shrink connectors for all the connections.
    Spud_Monkey and RZucker like this.
  9. Delmer
    Delmer Senior Member
    Jan 4, 2013
    6,367
    Use silicone grease, noalox, oxgard, cual gel, or something like that inside the heat shrink tubing. Even inside the crimp connectors if you want to get in an argument.
  10. RZucker
    RZucker Senior Member
    Jul 7, 2013
    4,104
    Mechanic/welder
    Wherever I end up
    And do not use a spike type crimper on heat shrink terminals. ;)
  11. Ronsii
    Jun 26, 2011
    3,544
    Western Washington
    I like the glue lined heat shrink connectors myself.
    RZucker likes this.
  12. Spud_Monkey
    Sep 15, 2018
    1,640
  13. Nige
    Nige Senior Member
    15,877
  14. old-iron-habit
    old-iron-habit Senior Member
    Nov 23, 2012
    3,857
    Moose Lake, MN
    No connectors for me. I still twist the wires and solder them solid the old fashioned way. Takes time which I got. Shrink the heat shrink over them and never touch them until the wire gets broke. Or when I forget to side the heat shrink on one end first and have to cut it to redo.
    Ronsii likes this.
  15. Ronsii
    Jun 26, 2011
    3,544
    Western Washington
    Same here, I really like to solder and heat shrink with adhesive or liquid tape... but unfortunately some people want me to use crimpies instead... cause it's quicker... of well.... more work for later ;)
    old-iron-habit likes this.
  16. LN Pipeline
    LN Pipeline Well-Known Member
    Feb 22, 2019
    98
    Montana, USA
    Can anyone recommend a quality tail light converter? Everything I’ve looked at has mixed reviews.
  17. Spud_Monkey
    Sep 15, 2018
    1,640
    That’s what these do, just quicker. You stick wire in heat up and it solders then heat shrinks with adhesive.
    https://www.grainger.com/product/TE-CONNECTIVITY-12-to-10-AWG-Splice-Connector-10K492
  18. Ronsii
    Jun 26, 2011
    3,544
    Western Washington
    Yep, I've replaced them before... they are very picky about the wire!!! if it ain't perfect and clean it will give you a high resistance connection which isn't the end of the world unless you happen to be drawing near limit on the wire ;)
    old-iron-habit and RZucker like this.
  19. Spud_Monkey
    Sep 15, 2018
    1,640
    Just dip it in some flux, all will be fine:p
    Ronsii likes this.
  20. Ronsii
    Jun 26, 2011
    3,544
    Western Washington
    I actually keep flux pens and cigar torches with some 60/40 rosin solder in my side drawer in the little service truck I drive :) used to keep an assortment of adhesive shrink in there too but other guys kept using it... they don't know how to use solder though ;)
    old-iron-habit and Spud_Monkey like this.
