2016 Kubota SVL 90-2 losing power going uphill. Any suggestions? Thx!
Discussion in 'Compact Track/Multi Terrain Loaders' started by Nathaniel P Gutchess, Jun 29, 2020.
  1. skata
    skata Senior Member
    May 10, 2007
    1,030
    midwest
    You could upload to YouTube.
  2. Nathaniel P Gutchess
    Nathaniel P Gutchess Active Member
    Jun 29, 2020
    31
    Travelers Rest, South Carolina
  3. skata
    skata Senior Member
    May 10, 2007
    1,030
    midwest
    It's kind of hard to tell what is going on.
  4. Nathaniel P Gutchess
    Jun 29, 2020
    31
    Yeah, I know. When I hit the hill you can hear the machine labor. I’ve got to get my wife to get closer!
  5. Delmer
    Delmer Senior Member
    Jan 4, 2013
    6,674
    The only useful part is the very end, I would expect the engine to rev back up and then quiet down at the higher no load speed if the engine was bogging down. I don't THINK I heard that.
  6. Nathaniel P Gutchess
    Jun 29, 2020
    31
    It did pick up speed as it got to a lesser grade.
  7. Nathaniel P Gutchess
    Jun 29, 2020
    31
    Can anyone tell me if this fuel petcock is on or off? This is how I’ve received it. Typically it runs parallel with the line for on??
  8. skata
    skata Senior Member
    May 10, 2007
    1,030
    midwest
    Usually valve handles should be parallel to be open. Perpendicular to valve to be closed.
  9. KSSS
    KSSS Senior Member
    Feb 27, 2005
    3,309
    excavation
    Idaho
    It would seem to me that if a drive motor was going out, you would really have to fight the machine to keep it from favoring the weak side while it is in travel. If it is doing that than the drive could be bad. It would be interesting to hook up a hydraulic attachment, like a rock rake , street sweeper or something similar with an orbital motor and see if it has the hyd. power to run it.
  10. skata
    skata Senior Member
    May 10, 2007
    1,030
    midwest
    But how are the pumps setup on this machine? The drives could have a separate dedicated pump.
  11. Nathaniel P Gutchess
    Jun 29, 2020
    31
    I am having to favor one side pretty heavily. Gonna block it up and make sure the tracks are adjusted properly, then see if I can get a mobile mechanic here to check out flow rates.
  12. CMC76
    CMC76 Active Member
    Mar 16, 2019
    41
    Wisconsin
    I was going to say that is just how they behave on grades until I watched the video. That grade doesn't appear very steep.
    I cut in the road on my new land last year, at the peak was 14% grade. I definitely was losing speed on that grade. Brought a case dozer out to cut to a more acceptable peak of about 8% at its worst transition. The dozer would track up it fine with zero hesitation. But my c238 still does not love the high grade with a full bucket. But the dozer and skid steer are nowhere near the same function.
    Your machine and mine are about the same hours, I've got a little more. But your grade looks less. If I were you, start saving for parts and see what the flow rates are. Granted your machine is for making money, mine is for personal use. But 3000 hrs +, have to be realistic with expectations
  13. Nathaniel P Gutchess
    Jun 29, 2020
    31
    Just got it back from Kubota, my hydraulic flow is really good. My left track was too tight. Dealer insists it’s normal and recommends just running it.
  14. JTWAT
    JTWAT Well-Known Member
    Mar 14, 2012
    163
    Central FLA
    Dumb question but do you have it in low range when you climb the hill?
  15. Nathaniel P Gutchess
    Jun 29, 2020
    31
  16. Legdoc
    Legdoc Senior Member
    Oct 6, 2007
    331
    south texas
    You said the hydraulic flow was good. What about the pressure? Also will the machine switch from low to high speed? Assuming both speeds work try low speed at 3/4 to full throttle have the arms down and push into a non movable object such as a large tree. See if both tracks spin. Whats the condition of the rollers and idlers. Lift the machine off the ground and with the tracks sagging are the rollers free, loose or seized?
