2016 Cat 249D has no power when i turn the key on.
catman54
Oklahoma
I have a 2016 cat 249D. The battery was bad so i put a new battery in. WHen i turn the key on, theres no power anywhere. THe battery cables are good, i have a good ground. I checked all the fuses and none were blown. The machine does not have a master kill switch, so thats not an issue. Anyone have any ideas of what to look at or what to do?? I appreciate all and any help.
heymccall
Western Pennsylvania
There is fuses on back side of cab wall, under the circled black covers.
Borrowed from this thread
catman54
Oklahoma
Was everything working ok before you swapped the battery.?
If you want an electrical schematic to go tracing power you’ll need to post a Serial Number.
Yes, everything worked perfectly before. SN is CAT249DKGWR00864. Thank you for the help
