Looks like this forum has some great info, so much that I signed up to get some help with my S510, any input would be appreciated.
Info on machine:
Info on machine:
Got a new to me 2016 Bobcat S510 with ~1000 hrs. Supposedly already serviced.
Problem:
I started to have intermittent trouble with the RH side drive, where it wouldn't want to move with either a load or say when in a ditch or where there was more force required to move the wheels. This issue eventually got worse and triggered an error code for low charge pressure.I stopped using the machine and ordered a new charge filter and parts to do the 1000hr service.
Troubleshooting performed:
I did the 1000hr service. I found that the charge filter was plugged with debris (I cut it open). There looked to be some sort of sludge with a slight amount of metal particles, very small. When changing the main hydraulic filter, I found that the plastic bottom of the filter had broken off of the filter itself, and was sitting in the bottom of the filter housing.
I changed the tank oil and ran the machine up. Changed the filters again and found small particles in both filters, which looked to be more sludge type debris, not really any metal.
I then disconnected the top hose going from the RH pump half to the top of the motor (reverse), capped it at the motor and connected a gauge on the hose. Ran it up with the parking brake applied, when trying to move (reverse) I hit 6000 psi on the gauge and kept climbing.
Next, I disconnected the bottom hose going from the RH pump half to the bottom of the motor (forward), capped it at the motor and connected a gauge on the hose. Ran it up with the parking brake applied, when trying to move (forward) I could only hit 3800 psi.
My thoughts:I changed the tank oil and ran the machine up. Changed the filters again and found small particles in both filters, which looked to be more sludge type debris, not really any metal.
At first I had thought the pump was failing internally, possibly due to residual debris stuck in the system after a component failure and not flushing everything out.
After looking at the filters, even though they were caked with debris, there wasn't much metal in them, just tiny specs, and not many of them. This is making me think that the debris found in the filters is actually remains of pieces of the bottom of the main hydraulic filter that broke off. Cooked plastic, or some other contamination? Perhaps the rotating group of my pump is good, just flooded with plastic debris, and my relief valves are not operating properly due to the debris being stuck in them.
My Questions:After looking at the filters, even though they were caked with debris, there wasn't much metal in them, just tiny specs, and not many of them. This is making me think that the debris found in the filters is actually remains of pieces of the bottom of the main hydraulic filter that broke off. Cooked plastic, or some other contamination? Perhaps the rotating group of my pump is good, just flooded with plastic debris, and my relief valves are not operating properly due to the debris being stuck in them.
1) My engine is the Bobcat D24NAP, has anyone pulled the tandem drive pump out without removing the engine? It looks to me like if I get a short enough puller, say the OTC 6614, I can get the pulley off the pump with everything in-place, then pull the pump out.
2) I have to take a look at the pump again, but I'm thinking that I can pull just the RH half of the pump out, while leaving the LH half in place? Any reason not to do this other than the LH half already being contaminated and needing cleaning?
3) Anyone have any better tech data than the bobcat manual for rebuilding the pump? Judging by the logo on the pump housing, it looks to be a Sauer or Sundstrand. Its Bobcat PN is: 6687863
