2015 cat D5K DPF filter issues
Discussion in 'Dozers' started by gnebgen, Apr 22, 2022.
  1. gnebgen
    gnebgen Well-Known Member
    Jun 8, 2015
    46
    fredericksburg, texas
    Hello, I have a 2014 D5 with 4660 hours on it. My yellow def light is staying on and the red alert sign is flashing only when the turbo is de rated, once it stops beeping the turbo is restored. It is regening and randomly blowing black/brown debris from the exhaust pipe. It runs fine and pushes fine, how long do the DPF filters last? Should it be changed at a certain engine hour? I did change the dpf sensor and it started regening with the dark brown exhaust , ran it for 12 hours, is this an indication it is working correctly and finally clean itself? Thanks, Gary
  2. Nige
    Nige Senior Member
    21,168
    For looking up information model year doesn't help so much. A Serial Number is better.
    Do you know how to show diagnostic codes on your monitor.?
    Have you looked and did you find any.?
    mg2361 and JakeRanisate like this.
  3. nowing75
    nowing75 Senior Member
    Aug 5, 2009
    805
    coatesville indiana
    we had a d5k clog the dpf filter. You can run a egr valve test if i Rember right and ours failed. Was told this is a common problem. Local dpf guy cut ours apart and cleaned it then welded back together.
  4. gnebgen
    Jun 8, 2015
    46
    Nige, my serial number is 0KWW00442, I do not know how to show the diag codes in the monitor. Nowing75, how did they clean the filter, I am not aware of any service like that here in Texas. I am just north of San Antonio. Thanks, Gary
  5. John C.
    John C. Senior Member
    Jun 11, 2007
    11,523
    A DPF only holds a certain amount of ash and when full or close to it you get the kinds of problems you are describing. In my experience the machines of that time period get from 4,000 to 5,000 hours when the unit has to be cleaned. You used to be able to get exchange units from the Cat dealer or they usually had access to someone who could clean them. You might also check with truck dealers who might know of someone who does that service. I don't remember the exact sequence of the menus but the password was usually either FFF2 or 9992 in that era. You would then have access to the service menu to check on fault codes. Someone will be along to correct that if I am wrong. Good Luck!
    mg2361 likes this.
  6. Nige
    Nige Senior Member
    21,168
    Sorry I was wrong. This is a K2 model and does not have the ability to see Diagnostic Codes on the Monitor. It requires Cat ET. I would suggest that before doing anything regarding scattergunning parts at it you need someone (dealer or local independent) to get ET hooked up and show you what you have right now.
    I agree with John you could probably be getting close to the point of operating hours that the DPF might equire either cleaning or an exchange replacement. But see above suggestion before proceeding down that path.
    From the Operator Manual
    Note: If the DPF light turns on, do NOT contact the CAT dealer. Simply change the machine operation to increase the exhaust temperature.
    If the soot level is elevated, the DPF light will come on. The light will remain on until the soot level reduces. The engine is safe to operate with the DPF light on as long as no other warning lights are active. Do one of the following actions to help reduce the soot level.
    The following methods are ways to achieve a higher exhaust temperature.
    1. Turn off the ECO mode
    2. Operate the engine at higher speeds
    3. Change the decel/brake pedal functionality so that engine speed does not decrease when the pedal that is activated.
    4. Increase the machine load by continuously pushing a heavy load for 30 to 60 minute.
  7. gnebgen
    Jun 8, 2015
    46
    Thank you all. Will proceed as suggested. I will run it this weekend and monitor, I do believe it is regening but slow to remove soot.
  8. John C.
    Jun 11, 2007
    11,523
    It doesn't remove soot, it just burns it to an ash that is stored inside the DPF. When the storage area is full, you get warnings and alarms and then you have to have it serviced.
    mg2361 and Nige like this.
  9. ahart
    ahart Well-Known Member
    Nov 7, 2020
    175
    Indiana
    The DPF filters on these machines are designed to last the life of the engine. The 5000 service interval is only on machines with an ARD combustion system. Cat says these one piece filters cannot be cleaned and must be replaced. We have sent them to a filter cleaning service and they cut them apart and tig weld them back together. This usually needs done if there’s another failure with the engine that causes excessive soot buildup in the DPF. Most of the time, the EGR system is at fault, egr valve stuck or something of that sort. I’ve also seen the EBPV (exhaust back pressure valve) not function correctly which causes low DPF temps.
    nowing75, mg2361 and Nige like this.
  10. nowing75
    Aug 5, 2009
    805
    coatesville indiana
    there is a local guy in indianapolis that all he does is clean dpf. He has to cut it apart as it is not serviceable like that larger equipment has.
  11. ahart
    Nov 7, 2020
    175
    Indiana
    Correct, fleet express is what the place is called that we use, it’s in a Indy. Im almost certain there will be a similar service in San Antonio somewhere. I’d just run a google search on DPF cleaning San Antonio.
  12. gnebgen
    Jun 8, 2015
    46
    Hello, I have contacted a company in San Antonio about cleaning, but if I decide to buy a replacement from CAT, does anyone have the service procedure to do so from CAT? D5K2XL, 2014, 0kww00442.
    Thanks to all. Gary
  13. Nige
    Nige Senior Member
    21,168
    Are you looking for the Part Number, or a procedure to R&I the filter, or both.?
  14. ahart
    Nov 7, 2020
    175
    Indiana
    There is no ash level timer to reset on these and they use RF antennas to detect soot load so you can just replace the filter and run the machine as normal. As long as there are no other codes that should work fine.
  15. gnebgen
    Jun 8, 2015
    46
    Thanks, Nige am looking to R&I the filter, I have a quote from Cat pending and I have someone to do the work as CAT's service call fees and labor are off the charts.
  16. gnebgen
    Jun 8, 2015
    46
    Thank you! Good to know.
  17. gnebgen
    Jun 8, 2015
    46
  18. gnebgen
    Jun 8, 2015
    46
    Hi Nige, I got the new filter and was wondering if you had the service manual piece to R&I the DPF filter. Thanks, Gary
  19. Nige
    Nige Senior Member
    21,168
    I sent it to you last Friday by PM. Did you not receive it.?
    John C. likes this.
  20. ahart
    Nov 7, 2020
    175
    Indiana
    Be sure to be gentle with the soot antennas on each end of the filter when you remove/install your hood assembly. If they get bent they will no longer function properly.
    John C. likes this.
