BigGuy610
I will start with the basic info on the machine first. I purchased this machine from an online auction. It said in the description that it had been filled up with gas and didn't run anymore. I put the min bid in thinking that if in the unlikely event that I would win it that I could fix it easily enough and use it for some small stuff I had to do and sell it. So to cut to punch line, no one else bid on it. I won it and have been the proud owner of this boat anchor for about 2 years. If you want to point out what genius I am you can save it cause my wife reminds me all the time.
The short story is so far I have flushed the fuel system, pulled the engine, replaced the high pressure fuel pump (common rail) and put then engine back in and tried to get it to start. No such luck. engine turns over fine, I hear the low pressure fuel pump working but even after cranking for quite a while it doesn't even give me a sputter. I checked compression and have around 390 psi on cylinders 2, 3, and 4. Cylinder 1 had 230 psi. Judging from the pile of starting fluid cans in the cab I am hoping the rings just might be all washed down with starting fluid and I might get enough compression back for it to work if I can get it to fire on the other cylinders... or at very least I should be able to get it to fire on the other cylinders and then figure out what to do with cylinder 1.
I originally thought this needed a special Volvo (or JCB) reader to get the codes off the machine and I don't have one so I didn't try. Since installing the engine and trying to start it I found the area in the menu with the error codes. I have 3 error codes: P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction, and P0098 Intake air temperature sensor 2 (IAT2) has an open circuit in the sensor circuit. Since the MAP sensor has the IAT sensor as part of it I replaced it and and tried to start it again. Turns over but no ignition what so ever. The error code didn't go away either.
My general strategy at this point is to check for fuel pressure at the injector, and a pulse going to the injector (already checked compression above). While looking for good ways to check those things I am also trying to figure out why my error codes didn't go away after replacing my MAP/AIT sensor. My thought process there is check wiring harness and if not that then the ECU.
Questions:
1. The biggest one is does anyone know how I can access the service information for this machine. I have spent a lot of time looking for wiring diagrams, how to reset the error codes, and lots of other specifications on pressures and voltages and can find much. I did pay $35 for what was advertised as a service manual on PDF online. It had about 4000 pages of various Volvo construction equipment but only about 20 pages pertaining to a machine like mine with a mechanical fuel pump. I have asked the Volvo dealer for info but that has not resulted in much.
2. Does any know how to reset the error codes on this unit. I have not been able to find anything on this.
3. If after resetting the error codes they don't go away, I am thinking of testing the wiring harness between the MAP/IAT and the ECU. Since I have not been able to find a wiring diagram I will just check each of the 4 wires at the MAP/IAT to the plugs on the ECU with continuity until I locate each of the pins and ground. After that I will look for shorts between those pins and other pins. Kind of crude but this is the best idea I have at the moment. If they all checkout good then I will have to figure out how to test the ECU. If anyone has any insight on this it is much appreciated.
4. I would like to confirm I have fuel pressure and an injection signal from the ECU to the injector. I can get a O-scope if I need to check this but first I was going to hook up my multimeter with the V DC Max setting and see if it is fast enough to confirm the injection signal. This might be a long shot. If you know anything about this let me know.
5. The other half of this is fuel pressure. Since this is a common rail fuel injection system I expect the the fuel pressure around 1750 PSI. Those high pressure test kits are expensive. I am looking for an alternative method, a place that rents them, or a do-gooder in the San Diego area that would loan one to a guy with a Volvo lawn ornament that is slowly crushing him to death.
Very much appreciate any feed back, help, or just general criticisms in all of my poor decision making.
Details if it helps.
2013 Volvo MC 110C with the EcoMax 444 TA4-55 S1.
Product Identification Number
GEO110SSTC2206006
Engine Serial Number
SL 320/40635 00821713
Questions:
GEO110SSTC2206006
