Good evening! I have a 2013 NH L223 with about 1,400 hours. It’s been running great for me, until recently. Had to replace a battery because it would be too low to start in the cold after only a few days sitting. After replacing the battery, using it to move bales, it would occasionally stall momentarily then rev back up. Happened a few too many times for me, so I parked it. About a week later, it wouldn’t start at all (crank but no start). Dug into my schematics and I don’t have a signal coming to my fuel cutoff solenoid (checked at pin 26 on my instrument cluster). I have power on Pin 7, but it isn’t transferring to Pin 26 (appears to all be fuel solenoid circuit). Unplugging the harness at the solenoid and applying power, it starts up fine. I have no codes on the display, and the instrument cluster Pin 26 to ground (Pin 20) shows 221 kOhm (should still be good per the manual). The instrument cluster wakes when I sit in the seat, and the seat belt indicator acknowledges when I click my seat belt. My pins at the cluster connection all look fine. I’m a bit at a loss at this point... not sure why the instrument cluster won’t pass the signal along to the fuel cutoff solenoid. Any ideas would be much appreciated - thanks!
