So I recently purchased a 08 Midi. Overall nice machine. I have discovered when using it as soon as I start to put some decent load on it , it will bog down and stall out unless I let off. Runs normal at idle and goes right up to full throttle when not on load no problem. I drained fuel tank and flushed it, changed both filters. Blew the line back into the tank. Still same issue. Ran with Fuel tank cap off to see if vent was clogged same issue. I can hear lift pump pulsating when I key on. I have not tested fuel pressure yet. Any ideas?
