Engine rebuild update. I had a starting problem. Had to get injectors and high pressure pump rebuilt. I got the motor running tonite but I only have idle. When I turn the dial throttle stays the same rpms will not increase. I can watch the electronic actuator move the throttle arm. Also when I lower the saftey arm on left side of seat I have no operation of any hydraulics. Keep in mind I bought this machine not running so I may be missing something. Any thoughts greatly appreciated. Thanks
