I drained the coolant...petcock on radiator...valve below injector pump...and took off heater hoses, and pulled them down below engine...got out 10 qts.
put in distilled water a couple times, ran till warmed up, let cool down, and drained...still about 10 qts.
manual sez capacity is 4 gal = 16 qts
i'm worried if I put in 10 to 11 qts of Bobcat PG pre-mix, that it may dilute with the 6 quarts of water that's not draining...and wont be the -37* it sez on the jug.
thinking of mixing some concentrate in, but I know too much PG isn't good either...
I told my wife to order me one of those refractor testers for PG, on Amazon.
any thoughts or ideas???
