jakejorgenson
Recently picked this up with a few issues when I got it to resolve. Wondering if any of you have a good source for understanding a few things that are wrong and where to start...
1. Dump wont dump because it is a clutch pump and the clutch part is bad. I ordered a new one from Muncie for this today. The wiring was totally fried to this so have to wire up a switch again and set this up. Wondering how the dump itself works once that is working. There is a lever in the cab but it doesn't budge right now so does it have to have the pump running to be able to use that manual lever to get it to move? (The people it came from originally it was a city plow truck and had a salter and they didn't use the dump bed.)
2. Speedometer/odometer goes in and out. Worked for the guy I got it from but he didn't know much about it and it was an auction truck. For me I basically drove it home and that was all so far and it worked for for a second but then stopped. ABS light is also on. Are they related or totally unrelated to each other? Sensor? Wire somewhere? Where to I start knowing it is intermittent like that and works sometimes. The guy I got it from said he drove it from VA to UT and it worked the whole way just fine.
Anything on this would be helpful. Just trying to figure all the wiring out from the fried wiring and what some of it is and trying to clean it up so we can use it on our jobs to haul instead of using our dump trailers so much.
