Jeff Hublit
2002 asv rc30 - 2149 hours - not sure what to do here but figured I’d reach out and see if you had any ideas! I bought this machine about a month ago.
It’ll turn if you’re moving forward or reverse but sometimes bogs engine down when doing so - been like that since I’ve had it just been putting up with it
Weak oil pressure you think? There is a small hydro leak from right side under skid by the sprocket/drive motor thing
Only thing I can think of I guess besides weak drive motor or weak hydro pump. Hydraulics on everything else work perfectly fine tho so kinda weird.
Also - tracks are not in the best shape and I hear popping now and then when turning (assuming it is the sprocket skipping on the tracks possibly.
