powerplusdude
Hello all! I am new to the forum and relatively new to owning a 2001 JD 750C LGP dozer with around 12,780 hrs.
1st problem: Started two days ago. Dozer works like a champ for first 30 minutes of day and then goes into "Slow Mo" mode after warming up. Blade hydraulics (6 way) do not slow down though. It is losing RPMs and engine sounds like it's under a load but it isn't. The first time it done it, it would barely pull itself back to the place where I was parking it for the night. Second time it done it, well, it's still out in the field. The dozer got so bad, it would not move at all and then the engine shut off. The engine will turn over but not crank up. I didn't try to crank that long as usually will crank right up just by bumping the switch. I am thinking that the fuel filters might be stopped up or it might be the fuel pump. I already got some new fuel filters to change out the next time I go to the dozer (1 hr away) and was wondering if there was anything else I could try or check to see if it could be something else. Any help or ideas would be greatly appreciated.
2nd problem: This started about 2 days ago also. Mainly when I am backing up, I can hear and feel a grinding in the right side track. It sounds like it is coming from the final drive sprocket. I have yet to check the oil level in the inner and outer final drive due to the dozer and my tools being an hour away from each other. I did, however, check final drive oil level around 50 hrs previous and it was fine. Do ya'll have any other ideas on what could be causing the grinding? Any help or ideas would be greatly appreciated.
I don't think the two issues are related but you never know. Oh, and yes, it does have diesel in it.
Thanks,
Mike
Thanks,
Mike
