I've been an interested bystander in this since the start. FWIW I would be ruling out a problem in the tank before going any further, even if that meant taking it off and turning it upside down. If something is floating around in there it could easily be producing the symtoms you are experiencing.
Well, you were right. The most logical way to approach a lack of fuel, start at the tank. I drilled a hole in a 5 gallon bucket, put in a fitting, ran a hose to the electric fuel pump, bled the system. Started right up and ran. RAN for over an hour. Started to clear up a little too in regards to the white smoke.
It blows white smoke when I accelerate, but it is starting to have a little RPM as well. Doesn't stumble as bad it did before. I ran about 2 gallons of new diesel in it, a couple ounces of Howe's Meaner and Kleaner. Seems to be working on getting that injector a little better than it was.
I'm hoping to find some biodiesel, but I can't find any in my area. Seems like one of those things that you see all the time, but can't find when you need it.
I have a side tank as well on the unit, I plan on cleaning it out, putting a new sender in it and give it a try.
THANK YOU GUYS FOR ALL OF YOUR HELP UP TO THIS POINT!!!!!!
