Just bought a 4410 of of an auction and knew it had some hydraulic issues before because it has an added cooler with electric fans and some stuff replaced. When I got the machine it wouldn't even lift the screed so I had my mechanic look at itnamd pump pressure was low like 900. We adjusted that to spec at like 1800, swapped all filters to spec Fiberglas with the spec oil and then everything seemed to work great. Aside from this issue the machine is in excellent shape and came with a ton of parts so it was worth the gamble I think. Tried a test strip today and after having the generator run for 45min to heat I took off and laid about 20ton at 10' wide up about 5% incline and the hydraulic oil started boiling out of the tank and gauge was pegged at about 350 degrees. Even with the aux cooler and fans running I couldn't keep it under 280-300 creeping along. I am very familiar with this same machine the last company I worked for I got one new in 03 and had about 6000hrs on it but never once had any issues like this. Any input would be much appreciated the mechanics I have are very inexperienced with paving equipment and I am trying to do all I can to get this machine useable!! Thanks for any advise!
