I recently purchased a used telehandler. All the functions seem to work fine. The problem I am having is after the machine is started and the system has enough pressure to shut off the low hydraulic system alarm the two hoses coming off the hydraulic pump start to jump, one hose goes to the spools near the front of the machine and the other goes to the rear oscillation lock cylinder. The pump is a G2020 Vickers. They seem to jump about every 4 seconds. They continue to jump even if your using a function. Ive talked to several people locally and they all say they've never seen one do that. My nearest repair facility is about 100 miles away. Does anyone have any ideas as to where to start trouble shooting the system or have had a similar problem?
