Bill and Joe,
Project complete! I pressure washed the machine for a clean work environment (10 AM yesterday) and began the repair at 12PM. I was 100% complete (cleaning tools etc) by 6PM last night.
Probably could have used a better method of removing the nut holding the piston on...but it worked (massive pipe wrench and a sledge hammer...I had to file the nut back down afterward). I completed the project 100% solo...with the help of the Bobcat, John Deer, and some flat straps. I did not remove any of the counterbalance valves at all. I used the hydraulics to do the work....I was a little nervous removing the end cap as I had extended the rod out completely. After recognizing that there was immense pressure and I was staring down the barrel of a hydraulic oil bath, I backed the cylinder off past the retract port which removed a considerable amount of pressure. Once the cap was removed, I used the hydraulics (thanks Bill) to push the rod out. Off course hydraulic oil went everywhere (which I figured would occur) even though I had 3 different catch basins. I did boom the machine up to save some of the oil. Inspection of the cylinder, rod, piston was all beautiful. I cleaned everything obsessively, greased the crap out of everything, and installed all components and seals exactly the way they were removed. I did booger up the interior of the end cap a little (thinking it was much like a race in a wheel bearing) and sanded any dings down for a smooth surface. This was my only mistake. Once I inserted the piston end into the cylinder as far as possible by hand, I removed the grease fitting at the end of the rod, covered it with towels, and used the John Deere (in low gear) to incrementally push the rod back into the cylinder far enough to be able install the end cap. I then used the hydraulics to push it back into the cylinder (once again incrementally) and reattached the end cap using the sequence I read in one of the other Lull repair manuals. I have the machine fully boomed up this morning to verify that the counterbalance valves are still functioning properly. I still need to replace the fluid that was lost as the supply house did not have AW68.
But that is all she wrote for my first ever cylinder repair!
Thanks again to you both for all of your help!
If you are ever this way, look me up and I'll buy you a beer or two. You can see what I use the machine for on my website
www.theprecisionconstructiongroup.com.
Thanks again, fellas!
Rick
