I get ten likes for the frame and suspension.
Only time I have ever had an issue spinning with air ride, is if you dump, and don't dump your bags first. I don't know if it's because they all become fully extended or what. All our tandems with air are set up to dump the suspension when you open the tailgate. The dumptrailers are that way as well. I notice a lot of guys don't dump the suspension on the tractor, and you see them spinning. I always drop the suspension. Even when I drop the float to unhook the gooseneck. I am not sure where guys hear stuff. Was told I shouldn't drop the bags when I'm loaded, Well I'm going to be empty in 20 seconds. Another favorite is I don't like to lock my power divider in because it's hard on the driveline. What???? I was taught by a mechanic that as soon as I leave the pavement that locking the power divider is easier on your axles, because you are dividing the power between two axles instead of a front or a back. Oh anyway back on topic. We had a couple Volvo trucks, and they were pretty solid
My understanding has always been that all 4 axles pull, but one axle, front or back can break traction and spin. When you engage the power divider lock, all axles pull, but in poor traction, one front, and one rear must break traction together, but still allowing your front and rear differentials to do their job in corners. Some of our trucks have the full lockup where you can choose between front or rear full lock or both.A lot of drivers have zero clue. The best one is that the front/rear does all the driving and the power divider engages the 2nd axle. No idea who comes up with these strange ideas.
But don't both axles pull, even in a car, until you enter a situation that causes your spider gears to allow the power to one side, like turning or spinning? When I say axle, I mean right and left side, as apposed to front and rear housings. We have a Peterbilt with eaton rearends. It always spins one front wheel, never a rear, unless you lock the divider. It has no lockup front or rear. The other trucks with rockwell rears, will spin one front, or one rear unless you lock the divider. Is that the design of the eaton over the rockwell. The internationals will also perform the same as the rockwell, spinning a front or a rear. I have wondered why international went the opposite way with the air. 4 wheel park brake with only maxis pots on the front housing? I have driven a few old macks with no switch, and they had those peanuts to engage by themselvesThe inter lock-locks the front drive, on locker type it locks both sides on one drive axle . Only one drive axle does the work that's why the drive tires on the right rear are always worn more
than the rest. You put air to the front drive on inter- lock with Eaton or Rockwell or Daimler drive axles. On International drive axles it is the opposite, those use air to keep them unlocked.
Really your interaxle is a diff for the diffs. Its a balance act between all 4 wheel ends. One loses traction, the other 3 still receive the same amount of torque but now its equal to what it takes to slip the wheel losing traction. When you lock the interaxle in, there is no differential action between the 2 drive axles.
