DirtyHoe
Lug nut mystery....
Ordered several new JLG 1/2-20 lug nuts(part #3300012). They showed up in original packaging, but they are a 60-degree cone. The parts manual does not show any other version of lug nuts. My rims appear to be original since they have 3 different colors of paint like the rest of the machine. The date stamp on the rims(9 hole pattern) is the same age as the machine(1996). The rims are stamped "16.5X9.75 DOT 06/95" and the tires are 12X16.5.
I read that you should NOT mismatch the tapers because they will work loose.
I checked the rim countersink with a protractor and it is definitely 90-degrees. So what is going on here?
Where can I find the correct one? I haven't found any online, but there are lots of 9/16 & 5/8 inch ones available.
Thanks,
Steve
Thanks,
Steve
