1995 Volvo L180 Transmission pressure error
zlssefi
Connecticut
Plowing during this last storm, the transmission pressure error message came up on the contronic screen. I scrolled through the menu and it showed the transmission pressure going from normal to error. The machine ran, shifted and pushed fine and eventually the message went away. Oil was normal height on the stick, no stink to the oil either. Think its a sensor flaking out, or should i have volvo run some pressure tests?
zlssefi
Connecticut
15w40 yes. It was about 30 degrees while we were plowing. Two weeks prior we were plowing at minus10 with no error codes. Transmission temp was 157.
funwithfuel
Will county Illinois
Mechanic
I'd check sensor connections, followed by sensor. Its digital, so it says to the computer , hey, everything's fine or oh no, I'm dying!. No in between.
Vetech63
Oklahoma
Can the sensor be checked with a multi meter ? what ohm values should i be looking for?
It depends on the type of sensor and what the values are. I have run into sensors that getting the setting parameters was impossible.
