AKieslich32
So I was running my 310d when I shut it down like normal and went to load some stuff in the bucket. Got back on the machine and click click. Would turn over. Bought two need batters still click click then I took of the starter and took it in to be tested. Starter was fine. So my concern is my engine is locked up but the machine ran great and always had maintenance. I can’t see why it would lock up all the sudden. If the main pump goes bad can it keep the motor from turning over. When someone hits the key and I watch the pulley on the crank moved about a 1/4” each time and does not return to the same position. It’s is turning and gaining a 1/4” of revolution each time you hit the start.
Any advice is appreciated. I want to troubleshoot and find the problem and not throw parts at it.
