1990 International 466 brake switch
Big ace
fl
I cannot find brake switch. Lights are not working. I checked fuse box and fuses are good.
mitch504
Andrews SC
I think the switch behind the seat is a tractor thing, so if you don't see it there, look all around the treadle (foot brake) valve which is under the dash if yourpedal hinges from the top. I have also seen them on the outside of the firewall, under the hood.
Big ace
fl
I have checked all arroind brake peddle. Nothing there. Checked outside firewall and nothing there
crane operator
sw missouri
Its got to be in the air line somewhere after the treadle. Follow the wires from the brake lights back toward the cab, and follow the air after it leaves the pedal. Somewhere they meet.
Interior pic shows where my switch is in a 8300. Behind the upholstery.
Firewall pic, that's supply to the pedal, and the lines out to the brakes. Find which set is going to the brakes and follow them.
Big ace
fl
View attachment 222686 View attachment 222687
My outside fire wall resemble yours but i dont see a pressure valve
Cheap "old" Geezer
Will generally look like a automotive oil pressure switch, larger diameter tin with a black plastic contact retainer center crimped in place, two wire connectors. Between the seats is most likely.
Big ace
fl
Yes, i actually purchased one from international
