I have a 86 lull with a funk transmission , when you start it the machine moves fine, then is starts to slip, if you shut it off for a few minutes and start it back up it moves fine for a little bit, I changed the fluid cause it looked real pink and milky , also did the filter, it also seem to be leaking out of a weep or vent hole right above the drive shaft, but does not leak all the time, sometimes it will leave a puddle, sometimes,a few drops , any ideas what this can be?
