Hey Guys, Update:
-The serial plate is gone off the machine, I found where the rivets were so I'm unaware of the serial number on the unit
-symptoms for the transmission is forward gears are good, (up to third), reverse is sluggish in all speeds, as in, won't move the machine if there is the least amount of resistance. When forward is engaged, it is a very positive movement, as in, no sluggishness and wants to go immediately.
-drained fluid and cut filter, nothing of note found
-removed suction screen, small amount of various material found, nothing that I would say that would lead to belief of clutch failure or any other type of bearing or gear failure
-replaced suction line to pump as there was spots that were rubbed pretty close to through and oil seemed to be aerating
-refilled sump with shell spirax t3 oil which carries the TO-2 spec oil still aerating
-checked pressures at reverse clutch and "D" clutch. had 145 PSI which is low, ( I believe the spec is 165-185 and not 215 -235 psi due to the 140 PSI observed, however, as I stated I don't have the machine serial # available to me to verify this. If there is a way using the transmission serial, this would be helpful)
-checked the voltage to the reverse coil and had system voltage, (12.6), I realize that this is a bit low but I also verified that the spool in the cartridge is moving freely out of, and installed in the collector housing, so I don't think that this is an issue but am willing to be wrong. I also verified that the resistance of the coil itself is within spec. 8.3 ohms
-removed and inspected the supply pressure regulator spring and it was intact, the spool looked good, but I added a couple shims to see if there was any change. After I got it back together, my pressure was 160 PSI, and was far more responsive on the gauge, but no change in reverse power
-removed and inspected the reverse shaft cover for scoring, there was a bit of wear, but the fact that my supply pressure isn't low at that clutch comparative to the other clutches would tell me that I'm not dealing with a leakage issue? Also inspected the hook rings on the end of the shaft and they appeared good, no cracks or chips that I could see.
-I'm at a bit of a loss as to where to go next. I don't mind pulling the trans but just don't see any evidence traditionally associated with a clutch failure. Is there a piston seal internally that could be at fault? How would I check this?
Any help would be appreciated.
Thanks!
