Monte Nelson
The 720A Motor runs (when you bypass the neutral safety relay) and the hydraulics work but when you engage to move forward or reverse the grader doesn't move.
I have replaced the following:
Neutral safety switch and relay
Checked with ome meter all transmission cartridges and replace one with dual plugs that was reading bad.
Ignition switch
I'm located in Ellsworth Co. Kansas and cannot find anyone to make a service call? Please help if you can. Thanks
Ignition switch
