Bobcat Crazy
I'm Glad to Hear of a Fellow that stays Positive as he Walks this Life +++. Good to hear you are getting a manual before Reassembly B-Crazy, I'll Try to help. You've been getting some Real Good Help!!! from some of these Great Guys on This Site!!!. So anyway While you are waiting for Parts.....I can Truly see how a damaged crank, with no counter weights and ground .020 under can easily break. But I Truly can't hold back from Any and All Reasonsones Why it Might Break, and what is the evidence for failure. I am out of my element on these machines!! So you Guys that Did earn your Stripes please forgive me!!!
Alinement!! Proper unstressed alignment is what kept my job easy over the years. Yeah getting all the sizes perfect or close was important, but it was alinement was what kept the machine running for the long hall. I was Spoiled, used computers and latter Lasers. The Problem I was thinking of is Soft Foot mainly. Easy check with a Dial Indicator. You can get somewhere with a feeler gage. No shims under the motor causes some concern. Unless it uses rubber Mounts.
B-Crazy I love Your attitude!!! I'm going to Run out in My Mind for a Little Bit, Please give me a little Grace and I'll settle back in my place Soon.
The Flex Plate is like the Flex Disc's couplings I used on High Speed Couplings (Those before me.. Faulk Gear Couplings). I used a Altra Flex where I could (they were much easier, cheaper, and more forgiving)( Those Before Woods). The Flex Disc was good in High RPM (with Great Balance) 5K, 7K ect.... They are soo Stiff They would about pull you into Horizontal Alignment before bolting down. They would Crack, Break, and Ruin your Equipment if They weren't Lined up Good.
Now for Soft Foot!!! Even for Big Heavy Machines the leverage of a Bolt can Twist a Gear Case so Bad as to pull the bearings, Gears, Crankshaft out of Alinement so Bad, You will Destroy it over Time. Even If Component to Component says the Alinement is Good. Say a Fresh Engine Rebuild is twisted in the frame so Bad it Wrecks the Center Crank Bearing and Nukes the Crank or over Heats it. Then you Add to that a stiff unforgiving Flex Plate.
One thing that sounds good is it was running when shut down. Also without injectors it turned over freely. Of course it did open up after the Crank Broke!
Can't say What Happened, But I sure Hate Fixing something Twice!!
Keep that Good Attitude B-Crazy
Hi Cat,
Yes I been getting great help from the Guys on this forum. The knowledge you all share is priceless to a shade tree like me!
I may or may not know more about engines than you do, that remains to be seen. But all of this soft foot and alinement stuff you are talking about, I can tell that I am not even close to being in your (Cat)egory (little play on words there) of knowledge base.
I am pretty good with a wrench or a ratchet but when it comes to the really technical stuff I can't even get to first base!
The engine and torq housing do have rubber cushioned mounts so I think I will be good on that part.
The bearings: with the exception of those which were on the #4 connecting rod (which was only rubble in the bottom of the pan), all mains and rods look really good. The thrust bearings look like they just came out of the box. I cannot believe how good they all look. If I had not taken these out myself knowing that the crank was broken into two pieces I would not have believed it. They must have stopped this engine as soon as it started making noise.
I pulled the sleeves today and they are in like new condition as well. I think I will have an awesome engine once I get the parts and get it back together.
From the looks of everything in this engine I don't think it had many hours on it after the last rebuild until the crank broke. It did have enough hours on it to be caked with dirt, dust, grease and even some gravel! There was pieces of gravel even between the engine block and the injector pump. So it was run a good amount to be that nasty but compared to the relation of the total hours I feel it was minimal.
Anywho I have all of the parts and block washed and cleaned (it is amazing what a hot water power washer set on 200 degrees can do). I have even started the painting of the block getting it ready to jump on when the parts come in. A couple of pics below. Enjoy!
B-Crazy!
