Everything you mentioned supported I may have to much jack pressure on motor I left a couple of the bolts in axle I thought they might help guide it steady but maybe there binding heading out now to get back at itSupport front with bottle jack and rear with floor jack you may have to play with tension on jacks to get level. Shouldn’t be that much force needed to split. Did you remove loader frame bolts that go through axle housing? And be sure you support loader frame with jack stands or blocks.
You need to go ahead and remove those bolts because loader frame will have tension on them. Also the backhoe mounting brackets have to come off. It’s been awhile sense I’ve split one so all these thoughts are coming back to me at random.
Kerosene would be better sense it dries cleaner but diesel works just fine.Hey guys projects going well so far pinions in gonna go try and get torque tube gasket and others plus shims today I have metal chunks and stuff in bottom of case guy told me rinse out with diesel fuel is that good idea?
