tracing
yes titles wrong its 580b not 540
When i got this thing, it would leak coolant out of the cap on startup. The filler neck looked bent like it hit a branch. I replaced the 1971 radiator with a new one, and the water pump and radiator cap. It didn't have a thermostat so I added a new one.
On startup it began blowing coolant out the vent tube on the radiator cap. I had a new ornamental cap so I replaced that with the cap that came with the new radiator same thing happened.
I removed the thermostat, and still blows coolant out the vent tube on cold start, 2 gallons came out.
On any other vehicle car truck tractor, i have routinely filled the radiator, left the cap off, let it idle until the thermostat opens, and if needed topped it off as the thermostat opens and fluid level drops. This is impossible to do in this case, if the cap is off it will blow out 2 gallons of coolant real quick on cold start at idle.
I'm not familiar with this engine and coolant circuit, but it appears it is pressurizing on start up which is not what I would expect to happen unless something is clogged up somewhere like some coolant bypass circuit.
Prior to installing the radiator I garden hose flushed the block no problem there.
Any ideas on whats wrong here ?
