1970 Case 580 CK
Discussion in 'Tractor/Loader/Backhoes' started by flyenhigh, Feb 27, 2021.
  1. flyenhigh
    flyenhigh New Member
    Feb 27, 2021
    1
    94061
    Almost starts but won't continue running. smokes. then no "almost run" until I wait a few minutes, then same thing. fuel to the pump, not much if any at the injector. Ran fine last month, maybe a little rough. don't know why it would make a difference, but, changed engine oil and filter, now this.
  2. thepumpguysc
    thepumpguysc Senior Member
    Mar 18, 2010
    5,770
    Master Inj.Pump rebuilder
    Sunny South Carolina
    If it’s got the check ball return fitting ON TOP of the pump, take it off the pump..
    MAKE SURE the shut off lever is touching the screw.(back side of pump) The cables r known to lose adjustment..
    Put the throttle in the WFO position
    and try to start it.. ALWAYS PUT THE THROTTLE IN HI WHEN TRYING TO START IT..
    Good luck..
  3. Eric a1cnc
    Eric a1cnc Well-Known Member
    Sep 19, 2020
    115
    New hampshire
    Can you explain why to put the throttle to Hi when starting?
    I am still new to diesels
  4. thepumpguysc
    Mar 18, 2010
    5,770
    To give it more fuel.. of course..
    I should have said, bring it off low idle..
    All the cranking specs for every injection pump tell u to put the throttle in hi before taking a reading..
    Eric a1cnc likes this.
