orville
The water pump on the tractor is leaking and needs to be replaced or rebuilt. I took off the hood and the front grill to see what I am in for. The radiator will have to come out and there is hydraulic lines going into the bottom of the radiator. Or are they lines from the transmission???? I will need to drain the hydraulic oil. Where is the best place to drain the oil, Bottom of the reservoir???
The sheet metal panels between the radiator and engine has hydraulic lines going through them, I am guessing by removing the panels that would give access to the lower radiator hose?????
Does this radiator just sit in a saddle at the bottom, or are there bolts down there holding it in??????
In another thread someone mentioned an on-line service manual, how do you access one if there is such a thing?
Any tips or suggestions on my endeavor?
