I have at least one of those!
WOW! 250mm! That thing opens up pretty wide! :duh
Hate to bust your bubble but adjustable wrenches are measured by overall length NOT the opening size! If i turned it over you would see it is also labeled a 10 inch wrench. Really would make more sense to mark them as to the opening size! Who care how long the wrench is I want to know it will fit the bolt or nut!
While I'm wasting every ones time I might as well mention the REST OF THE STORY on that wrench.
Seems I was going through some junk at work a few years back and found a Williams 10 inch adjustable wrench and the only thing wrong with it was the screw/axle for the knurled adjusting screw was missing. Did not know of any Williams tool dealers around the area so I went on line. Found out that in fact Snap-On had bought the company but was still selling them under the Williams name. Just for fun I emailed the "Contact Us" link on the Williams page asking if I could get a replacement screw. A short time latter I got a reply that said they did not sell parts but they would warranty the wrench if I sent it to them. So I cleaned it up a bit so it did not look like I had pulled it out of a scrap pile and mailed it in. Think it cost less than $5.00. Sure enough a couple weeks latter this brand new wrench showed up in the mail. Also it is one of the best working adjustables I have ever seen sliding jaw fits as tight as it looks in the picture.
68 now thats a good one hhahahhahahha Scary part is i know of some who would actually do something like that ...hey put a patent on that stuff and advertise it as the finest sawdust with the secret moonshine anti slip ingredients fresh from the virginia hills and sell for $19.95 a bucket .....If you build it they will come.......:jawdrop:jawdrop:falldownlaugh:falldownlaugh
from fliptop's post:
"In terms of the mechanic shuttle, I can see where the problems we are having may be overcome. However, I would think that the ability to push into a fill pile, into snow, or into compost may be lost because the engine will be directly coupled to the driveline through the clutch. So you would have a greater chance of stalling or riding the clutch to do some of the things we can do with the torque converter."
It's certainly possible to stall my CK with the mechanical shuttle if it were to come up against an immovable object like a large tree, some ledge, or even a pile of stone or fill if you just push into the bottom and don't curl or raise the bucket as it fills up but in first gear and low range - something my power shuttles don't have - that thing will just about crawl up a wall and has no trouble filling the bucket up without stalling. It's more likely to spin the tires - even with chains - and jump up and down. I replaced the clutch in it when I first got it over 30 years ago and I don't baby it. She still pulls the front wheels off the ground by accident so the clutch is still holding up. I really prefer the manual shuttle in the CK and I like he HI/LOW range that can be used in all gears. I have the power shuttles in the newer machines and I like the electric cut out switch on the loader handle and the brake pedals that acts as a clutch but I think those came later.
Also had a guy at work who could not understand when someone mentioned getting a new "cordless screwdriver" he would say "Heck, none of my have cords, what's the big deal?"
No cords on his screwdrivers (you probably should of told him theres battery's in the handles while you went to lunch) hahahahah
kshansen, That was an attempt at humor. I'm not the sharpest tool in the shed but I do know it doesn't open up 10" - that's why the "duh!" headbanger.
Grady whats that electric cutout switch on your newer rigs used for ??????? just curious......I think i would like the mechanical shuttle just because they had obvious problems with the power shuttle on the cks ....
xpack, It's a clutch cut-out switch. It's sort of an electric clutch as it gives you a temporary neutral as long as you have your thumb on the button on the loader handle or foot on the brake - my C has a switch on the dash to enable or defeat that feature. I think it's an electric solenoid that controls the hydraulic flow. Some have a switch on the floor you can step on for the same thing. Does your's do that if you step on the brakes?
I understood that and was also trying to make a little funny! In case you do find one that opens to 250mm I'll let you use it all you want! Don't even what to think about carrying that one around.
1968 and onemank6 - boy you guys sure posted a TON of great info on this forum. I just got a 1967 580ck given to me by a widow down the road. it sat 5 years unstarted, and I'm in the process of trying to make her good again. I'm up here in Michigan. Some of the work will definitely be easier with all the photos you posted. I definitely have a lot of learning to do having never worked on one of these before.
