STX123
I got a some time to work on the machine over the weekend. Thank you all for your replies, it has help alot.
I was able to adjust the loose track. I could not get grease into the hydraulic tensioner. I thought it was at it max. Upon further inspection I found the grease zerk was blocked or broken. I replaced the grease zerk and was able to get the track tight. It is now close to its max but the track is tight. I got 8 of the 12 bottom rollers to move. The ends one would not move. I soaked them with pentrating oil and will try again another day.
The machine has a case 301 diesel engine in it. I have a low oil pressure issue. I changed the oil and filter. I put a new oil line and new gauge on it. I fired it up. The engine needs a small shot of starting fluid on its first start of the day. No glow plugs or heater intake on it. The engine runs great and sounds good when running. I put 15/40W oil in it as it will only be ran in the summer. I had the shop to about 50F degress. Not bad considering its been below 0 recently. The new line plugged with sludge right away. I shut it down and clean the line out and fired it again. Same thing plugged. I tapped the oil line and gauge into the oil filter hosuing and tried again. I fired it up and was getting 2 psi Damn i thought. I let it warm up. When it warmed up I opened the throttle all the way up and got 18 PSI. Still to low as the service manual calls for 40-45 PSI at full throttle. Warm at a idle was still getting 2 PSI. I am going to remove the oil pan and see if the pickup screen is plugged and clean everything I can. I am hoping I have a sludge problem. The shop manual say to check the relief valve on the oil pump. It could have a broken spring. The relief valve can be adjusted to gain more oil pressure. I may turn it up. Any advice on this issue is welcome.
