Ken Miller
This tractor would start easily with weak battery whether cold or hot after redoing the heads. While moving to re-attached backhoe front wheel lugs popped and wheel came off crashing to concrete. Motor kept running fine but after turning it off it would not restart after replacing front end/hubs - unless we used ether.
Thought something to do with fuel so rebuilt fuel pump - no change: had it rebuilt again professionally - no change; replaced fuel filters and ensured all fuel lines open - no change; Checked compression while trying to start: 260-275 all 4 cylinders vs supposed to be 400 when warm and running 200 RPMS so don't know if 260-275 is good or bad?
Started with ether - individually loosen all injector fuel lines and motor ran rough each time until tightened injector. Adjusted fuel pump timing for best running. Shut off and still won't restart when warm even with ether (or a propane blow torch), but will after cold with ether.
Impact of wheel coming off only change we know between easy start and now hard start. After starting problem appeared we did have generator rebuilt and got new regulator. We are stymied - don't know what else to check? Anyone know what the compression is supposed to be when cold cranking starter? Other suggestions? Have video of it running if that would help.
