Finished the 15spd, had to machine a 14613 rear bearing retainer to be able to install a magnetic pickup for speedometer. Parts for these older gear boxes are getting hard to find.
Finished the engine also, completely wired and plumbed so when it comes time to set it in the frame, connections will go pretty fast. And I finally got the headlight buckets repaired
and polished. The right one was cracked from headlight opening to fender edge the other one had a piece broke out of bottom next to radiator housing. A bunch of time in cutting
and fitting a piece of 3/8 aluminum stock to repair it then carefully blending that area to match. 30 hours -maybe less time involved in those two items. Next job is remove the
rear drives and tear those down and inspect.
