melben
- Joined
- Jan 14, 2008
- Messages
- 1,026
- Location
- Williamsport, Pa
- Occupation
- Retired 50 Yrs with Case dealership
I would greatly recommend you not to run that engine on starting fluid long enough to raise the loader, you are begging the engine to break its compression rings, starting fluid is very dangerous if there is no fuel delivery, I just completely did a 188 over that was destroyed by starting fluid, it wasn't pretty. I have found over the years that engines get starting fluid dependent and I do not think you want that, I would very much recommend that you use another machine to lift the loader to get the safety prop in place, If you lift it with another machine you will have to block it under the rear or it will just pick the whole machine up on the rear wheels, If it ran before i suspect you will find the problem near where you wired those lights in, all this happening at once seems more than a coincidence.
