I have a 150 mark IV that the oil pressure light has been coming on sometimes,we replaced the sender but that did not help.Then we put in a mechanical pressure gauge, when the light came on it was still in the 40 on idle to 75 full throttle pressure range.Local dealer said 75 was to high that it should not top 50 , so we cleaned the pressure relief but it was fine.He also said it could be a wire shorting out.We tried to check that out , one wire is grounded and the other has 24 volts to it so I don't understand how that can be it.If on the hot side I thought it would blow a fuse and if short on ground side , what if it rubbed cause its already grounded.I don't know if its a computer thing or how to find it or a broken wire with out knowing where to start on other end.The mechanical gauge says all is well so I feel as we are chasing a ghost.Any good ideas? It has a cummins motor that runs fine.
