I Have 2003 140 H 2 and it has a problem with the throttle lock indicator lamp not iliminateing on the console when the throttle lock is switched on which puts up a check engine light indicator.The throttle lock works as it should on the grader but the check engine lamp is annoying,have visually checked as much as possible EG globe but the reason must be a bit deeper maybe electrical . Thx Ocka
