Is anyone using a 12v hydraulic pump on a ground bearing / single cylinder RGN trailer ?
Want to use a trailer on an older tractor w/o wet kit. The trailer only has the front ‘kick stand’ cylinder, and don’t want to add a full gas powered pony motor pump, since it will be rarely used.
Would like to use a 12v Hydr pump if possible.
Per the trailer Mfr, the cylinder spec is 2500psi / 20gpm max.
If so, what did you use ?
Suggestions ?
Suggestions ?
