pedrocar
Hi 12g sn3wco1360
This grader has 20k on the trans never been apart serviced 200hrs ago very clean ,pushing a heavy load started shuddering barely turning the wheels in 3hrd gear ,went to Cat checked pressures all in spec ,filter clean ,could it be just a case of old o rings cracking/failing leaking under load all other gears are fine
