Several other things can factor in here. I don't know what series 644 you have, but Deere 4 cyl diesels, I've never known them to crank particularly fast, whether it's an old 4239 or a newer 4045T. We have a 10K Genie forklift with a 4045T, original design by Genie is the engine is at the year and the single group 31 battery is about mid frame on the right side. Not enough room in the box for another battery, and they used 2/0 cable, but that's about 10 ft of cable, it never cranks fast, and in winter, forget it. I've replace starters, replaced the battery, made sure the cable was good with good ground, still hard cranking in winter. One day I had enough of that machine, built another battery box closer to the engine, added a second group 31 battery with a shorter 2/0 cable to the starter. Now with those two batteries it cranks good enough to start. Another thing that can cause slow cranking, I'm not familiar with the Lull 644, but some machine hydraulic systems are designed to have a high stand by pressure for the pump. The Genie 844 is like that, as soon as you crank it starts building pump pressure, which labors the starter. On that machine Genie fitted a solenoid valve to de-stroke the pump, simply mash a push button on the dash while you're cranking to start the engine, once started you release the button and it engages and loads the pump. I don't know if your 644 has something like that, might want to check.
