12.7 Detroit
Discussion in 'Trucks' started by petepilot, Jan 22, 2020.
  1. petepilot
    petepilot Senior Member
    Jul 7, 2018
    1,234
    central shenandoah valley va,
    94 yr mod 12.7 det. Died on the road this am as if ign. Turned . off will not start back not fuel problem . any thoughts?
  2. RZucker
    RZucker Senior Member
    Jul 7, 2013
    4,102
    Mechanic/welder
    Wherever I end up
    Look for ECM power fuses from the batteries first.
    Tenwheeler likes this.
  3. petepilot
    Jul 7, 2018
    1,234
    Power prob. Was my first thought. Have not checked it yet myself had it towed to yard
  4. funwithfuel
    funwithfuel Senior Member
    Mar 7, 2017
    3,044
    Mechanic
    Will county Illinois
    Should be 2 fuses. 1 for each set of 3 cylinders. If you lost 1 it shoulda kept running on 3. If you dont have any error codes, pull the sir compressor discharge hose off. Crank the engine and see if you get delivery. If the accessory drive fails you lose compressor and fuel pump. Dragged a lot of Freightliner off the highways for this common problem
    63 caveman and Tenwheeler like this.
  5. LN Pipeline
    LN Pipeline Well-Known Member
    Feb 22, 2019
    90
    Montana, USA
    My neighbor had this problem with a 12.7. Ended up being low coolant. Guess there is a shutoff switch for this?
    I don’t know if your problem is that simple, but you could check.
  6. crane operator
    crane operator Senior Member
    Mar 27, 2009
    4,339
    sw missouri
    Will it crank, but just not start, like its out of fuel but you have fuel? Mine had a rubbed through wire behind the air compressor. I think its the wire that ran from ecm to crank sensor on the front of the engine.
    funwithfuel likes this.
  7. petepilot
    Jul 7, 2018
    1,234
    I was able to bow out on this one .Turned it over to a shop that is supposed to have the talent & equip.to handle any Detroit prob.:) but yes it would crank but no go.
  8. petepilot
    Jul 7, 2018
    1,234
    accessory drive link took a dive
