1150b help
Discussion in 'Dozers' started by miller125, Dec 3, 2019.
  1. miller125
    miller125 Member
    Jun 17, 2018
    20
    Indiana
    I have case 1150b I recently replaced control base gasket and fwd and reverse rings on the rear of the machine.When I went to move the machine I had 280 on pressure gauge than went 0 and would not move. I have checked suction side ,filter , gauge strainer, and the tube above moderator valve . The pump is 6 months old . Took the pump off it looks good and fluid leave is good. The machine will only move a few inch when first started. Could the problem be the pressure relief valve? I am lost looking for help thanks
  2. Dave Neubert
    Dave Neubert Senior Member
    Jul 19, 2018
    463
    Monroe NC
    Check to make sure the inching pedal is not froze up
    Vetech63 likes this.
  3. alrman
    alrman Senior Member
    Jun 20, 2009
    2,696
    QLD Australia
    There is an upper & lower gasket on the control valve - did you replace both of them? I have seen the upper ones blow out also.
    You need to check the spring #26 at the variable orifice spool also.
    DMiller and Vetech63 like this.
  4. Coy Lancaster
    Coy Lancaster Senior Member
    Dec 19, 2014
    1,227
    service tech
    Arkansas
    The modulator valve could be stuck. Like Dave said check the center brake pedal make sure it's not stuck.
  5. miller125
    miller125 Member
    Jun 17, 2018
    20
    Indiana
    I did replace item #25 because it had broke in half and modulator valve I unhook it to make sure it was seated
  6. miller125
    miller125 Member
    Jun 17, 2018
    20
    Indiana
    I will recheck the top control gasket it was replaced this summer
  7. Coy Lancaster
    Dec 19, 2014
    1,227
    service tech
    Arkansas
    Item 18 is your modulator piston it could be stuck.
  8. miller125
    miller125 Member
    Jun 17, 2018
    20
    Indiana
    Can the spool be remove or piston be checked without pulling detent out?
  9. Coy Lancaster
    Dec 19, 2014
    1,227
    service tech
    Arkansas
    I meant item 19 is your modulator piston, You can remove the modulator valve as an assembly and then use a pair of flat nose snap ring pliers to remove piston.
    If you need to remove a spool the you have to remove the detent.
    DMiller likes this.
  10. alrman
    Jun 20, 2009
    2,696
    QLD Australia
    When you replaced the spring (#26), the roll pin (#29,30) was still in place?
    Coy Lancaster likes this.
  11. miller125
    miller125 Member
    Jun 17, 2018
    20
    Indiana
    Well check moderator piston is was not stuck came out with magnet. As for valve control gasket all three were good. Yes alrman I replace # 25 it was broke the springs were good. Also check control valve ports while checking gaskets. I guess I will check pressure relief valve next. Thanks for help if you guys have any more input I welcome it
  12. Coy Lancaster
    Dec 19, 2014
    1,227
    service tech
    Arkansas
    May have been asked but what is pressure gage showing? Is the hi lo lever engaged?
  13. miller125
    miller125 Member
    Jun 17, 2018
    20
    Indiana
    Gauge show 0 at any any range. Had the pump check yesterday. So now back to square one. Now going grease all suction fittings to see if I miss one.
  14. Coy Lancaster
    Dec 19, 2014
    1,227
    service tech
    Arkansas
    Pull the lower rear cap off and check seal rings there could be a problem there.
  15. miller125
    miller125 Member
    Jun 17, 2018
    20
    Indiana
    Update on the progress I have eliminated the pump and torque converter. With a simple test of checking pressure at the second filter hose and had 280 psi. A case mechanic told me this he said if I had pressure there than it’s in control valve. What do you guys think?
