06 CAT 277B restoration
Discussion in 'Compact Track/Multi Terrain Loaders' started by hvguy, Jan 30, 2017.
  1. thepumpguysc
    thepumpguysc Senior Member
    Mar 18, 2010
    5,773
    Master Inj.Pump rebuilder
    Sunny South Carolina
    If your talking about > getting them unstuck from the head.?? anything is worth a try.. but u might wanna consider the 50/50 mix of ATF & Acetone in a spray bottle.. THAT creeps..
    Do u have a "slide hammer" injector remover.??
    That's usually the ONLY way your gonna getm out..
  2. hvguy
    hvguy Senior Member
    Sep 11, 2016
    350
    Conroe TX
    I have a 20lb slide hammer and adapter I made for these injectors. I was 99.9% sure I was going to break the top off the injector when I tried last
  3. thepumpguysc
    Mar 18, 2010
    5,773
    Dam.. U certainly don't wanna break'm..
    If u really wanna getm out use the 50/50 mix & let it sit a day..keep squirt'n it & then try it again..
    I probably wouldn't run the machine w/ the acetone in the mix.. u never know what its gonna do if it hits a hot manifold..
    Good luck.
  4. hvguy
    hvguy Senior Member
    Sep 11, 2016
    350
    Conroe TX
    Thanks! I've used that mix on seized engines with good luck.
  5. hvguy
    hvguy Senior Member
    Sep 11, 2016
    350
    Conroe TX
    Any idea why it would be harder to start in the warm weather? Before it would crank 1 revolution and fire up, now it takes 8-10 spins.
    I've got serious buyers remorse right now.
  6. skata
    skata Senior Member
    May 10, 2007
    1,030
    midwest
    i have a 96 perkins 1004 engine and got 3 injectors out, but the last one is stuck. i'm able to unthread the upper portion, but that leaves the lower half in the head. got a hammer puller coming tomorrow. hopefully she comes out.
  7. thepumpguysc
    Mar 18, 2010
    5,773
    Don't unscrew it.. its got springs & shims that'll fall..
    & the most important part that needs replacing, the tip, will stay down in the stuck portion..
    Before using that new hammer puller, snug the body back together.. the last thing u wanna do is snap it in half & hafta pull the head..
    EVERY PHASER Injector {1004} I've seen, is rusted on the outside.. & your gonna hafta use penetrating oil.
    Which leads me to my next statement.. U gotta clean that bore before the new ones come in..or rebuilds back..
    Good luck.
  8. skata
    skata Senior Member
    May 10, 2007
    1,030
    midwest
    yes, i snugged the injector back up. soaked with lots of penetrating oil, and waiting for the slide hammer to arrive.
  9. hvguy
    hvguy Senior Member
    Sep 11, 2016
    350
    Conroe TX
    Well, it's been a minute.
    The rebuilt pump finally locked up, the head and rotor became all 1 assembly lol.
    Thanks to some super nasty fuel I used. I figured the filter would catch everything, turns out the chemical makeup was sooooooooo bad, it fused the rotor.
    No worries, ordered a new pump from cat. They sent one that had 5 fuel lines and 2 coolant lines lol. Clearly not what I needed. Turns out that's the newer style pump. Returned and got the right one. Installed it and I've never heard it run sooooooooo good.
    Fast forward 2 days, its running good until it starts starving for fuel? I can hear the lift pump spinning super fast, gargling, then it runs ok for a minute then falls on its face.
    Limp it back to the trailer and back to the shop. Pull the feed hose to the pump and hookup to a clear hose spilling into a bucket.... It's a bunch of air.
    Pulled the fuel pickup pickup lines and the suction side is absolutely rusted to death. Full of pinholes. Check online for the replacement part, only to find out it's $137, needless to say I built my own for that price lol.
    Used some acid flux, silver solder and copper refrigerator line.
    IMG_20191222_111030.jpg IMG_20191222_115257.jpg IMG_20191222_115302.jpg IMG_20191217_105626.jpg
    mikebramel likes this.
  10. Welder Dave
    Welder Dave Senior Member
    Oct 12, 2014
    5,343
    Copper is NOT recommended for fuel lines.
  11. hvguy
    hvguy Senior Member
    Sep 11, 2016
    350
    Conroe TX
    Why's that? Vibration will cause it to crack?
  12. Welder Dave
    Oct 12, 2014
    5,343
    Vibration cracks and the copper can have reactions with the fuel. There's a reason it wasn't copper from the factory. There's more info on the net.
