a bit new to the skid steer world have some questions I’m in the process of changing axle bearings does one need to change the oil in the transmission ? Does it need to be drained to make this repair? How do you get out this oil ? It almost looks like you have to pump it out I’m assuming bad bearings would cause metal to contaminate the oil also is there separate oil for the hydraulic system and transmission ? Anyone have an idea how much oil it holds ? Thanks in advance!
