Brian_216
I found my way over here after a few posts popped up similar to my issue but I’m at a loss.
I just bought an 03 cat 248 high flow machine. The seller didn’t tell me the fuel solenoid was missing and you had to pop a plug out and use your finger to move the rod to shut it down. Thankfully he showed the guy I sent to haul it home. I expected to fix small issues, but this just made me mad.
I ordered a solenoid and it works but smokes the fuse in a few seconds. I found a schematic that claims to be for my machine and I have been doing some testing.
With the key on I get +12v on the green green wire, and 1.5v on the heavier gauge red wire. The solenoid has a start and run input. One isn’t meant to hold it open, the one that does that is the heavier wire that comes off the relay.
Through process of elimination I found the red from the solenoid plug and it’s other end at the relay. The other heavy wire in the relay is +12v regardless of key position, I am not getting anything at the other two wires that drive the coil in the relay. Like 7.5 volts or something.
Now for the part I can’t seem to wrap my head around. The schematic shows color and wire size for all the relays in that position, none of them match what’s in front of me on my machine.
