Facundo Nuñez
Hi guys, i'm new to this forum.
I'm having some troubles with a genie telehandler. Equipment runs ok except for a low speed forward transmision.
Found some wiring disconected below the pedals, acording to the manual, they should go to the inching pedal sensor.
Machine "thinks" pedal is being pressed and so wont go forward fast.
Simmulated PWM signal to the valve and it moved OK, just a bit inconvenient to be moving a duty cycle potentiometer with the hand and accelerating the engine with the foot at same time, hehe.
Pedal assembly seems to be missing that sensor and the mounting hardware for it. Spare part is impossible to get here so we will try some diy solution.
Does anybody know what kind of sensor it is? potentiometer? which value? attached to pedal rotation axle? any pictures of it?
0v and 5v voltages are ok on the wires that were found disconnected, and the third wire is the return signal according to the electrical diagrams.
thanks in advance!
greetings to all from neuquen, argentina.
thanks in advance!
