Volvo EC210 blc V1067
Dave Neubert
Monroe NC
I need to plumb a thumb on this machine it has a hammer and a shear circuit the shear circuit will get me what I need to the thumb but I need to reduce the pressure to 2500 psi. I looked on the control valve and it does not appear to have a individual circuit relief for this section is there a place to reduce it or do I need to plumb inline reliefs in the system
Mimir
Kenya
Can someone please help me identify the obd port location in my Volvo ec210b
funwithfuel
Will county Illinois
Mechanic
Maybe, let's start with hitting new member introductions. Where you're at, what you're doing, that sort of thing.
In regards to your question, On the right side back panel there should be a small rectangular opening . It may still have the trim plug which is the same size, has a little pinch grip to remove. Behind the hole is a small black plastic rectangular connector. That is the VCADS connector. That machine was not fitted with OBD connectors. Hope this helps
