Got fuel transfer pump replaced today and have full pressure at full throttle now. Was pretty easy to repair, only 4 9/16" bolts and the fuel supply line. If you have rubber compression fittings inside your supply line, the part # is 4H-2662.
Have a question about 2 open ports on the new fuel pump. I plugged them with 1/8" npt plugs. Read the service manual about replacing/installing the fuel pump, it says something about a drain line, but isn't very specific.
Is the port on the pump I'm pointing at in the pic with screwdriver supposed to be open and vent to open atmosphere?
