charles_
The water pump is on the front of the motor and i see no bolts to remove the fan. Is it pressed on ? do i need to pull the radiator first ? Anyone Know ?
That's kind of why I was asking for pictures.Unless it had an old motor transplant the fan don't need to come off.
bob
Some day if I have the ambition and wife isn't around I might stop and take a look and some pictures. Wife would be worried someone would call cops or start shooting!
Thanks for clearing that up, like I said it's been many years since I worked on either of them so I was not positive which way it went.The D333C engine has the water pump mounted high as in the first picture (kshansen) the later water pump bolts in from the lower front case, as in the second picture and the 1974 post, the engine change came in the Spring of 1973.
tctractors
